The card microcontroller has detected that the input voltage to the card is too high. To prevent damages to the card, it has been shut down.
Power cycle the chassis or wait around 30 minutes to see whether it will come back to normal operating range or not
Critical
Input voltage for %slot% in channel %channel% is higher than normal operating range. The card will be shut down
| Name | Type |
| slot | String |
| channel | uInt |
